gazchill 0 Posted June 3, 2007 Report Share Posted June 3, 2007 Hi,I've got a couple of problems with my ABS that I hope you can help with :-i) The ABS Light bulb (on the little circuit borad behind the dashboard) has blown. Can anyone point me in the right direction to get another one. Can't find one at a breakers yeard and the dealer wants 80 notes for a new one - Which is a bit steep for a LEDii) The ABS has had an intermittend fault for some time (hence the light blowing) VAGCOM comes up with a rear right intermittent sensor issue. Sensor has been replaced and its been cleaned out down there but I still get the problem from time to time. Although if you road test it with a diag tool attached the ABS counters always show the same speed. My mechanic seems to think it might be a wiring issue from the sensor back to the ABS ECU. I'm sure i've read on these forums before something about ABS Rings ? I mentioned this to him and he said if it was the rings the fault would be there all the time. What do you guys think ? Is my mechanic right ? What do ABS rings do anyway and could it be the wiring ?Thanks for any assistance.Gaz Link to post Share on other sites
kalv 0 Posted June 3, 2007 Report Share Posted June 3, 2007 Check ebay for the ABS bub.. can get them as part of the unit (SRS and ABS together)... Link to post Share on other sites
VR6Rich 3 Posted June 3, 2007 Report Share Posted June 3, 2007 Seems to be a common problem the rear right sensor going, ive had the sensor replaced twice but this time for the MOT I replaced the ABS pump and ECU and my ABS is all sorted now. I think the connection with the ECU must get fragile after a while on a particular pin or something to cause the common rear right sensor problem.BTW I got my pump/ECU from eBay for £2.99 ;-) Link to post Share on other sites
steveyj 0 Posted June 13, 2007 Report Share Posted June 13, 2007 I had the same fault (rear right) around 2 years ago. Fitting a new abs sensor didnt resolve so I replaced the ABS pump and ECU. This sorted everything out until about 2 weeks ago. I'm now back at square one I am also experiencing overheating due to the handbrake mechanism not returning properly (Is the abs problem a result of the heat issues in that area?)I remember reading (back then) that the abs ecu is at fault and can be replaced/fixed. Does anyone know how to repair? Soldering was mentioned...I also seem to recall that the abs ecu was also used on some volvo models!?Steve Link to post Share on other sites
VR6Rich 3 Posted June 13, 2007 Report Share Posted June 13, 2007 Im going to take apart my old ABS ECU to see if I can find out what the problem was, might be a dry joint or a broken track or something. Obviously related to a week point on the pin for the rear drivers side sensor though! Link to post Share on other sites
steveyj 0 Posted June 16, 2007 Report Share Posted June 16, 2007 Have a look at the following links:http://www.bba-reman.com/content.aspx?content=teves_20_fitted_to_volvo_850_and_v_w_%27s BBA Reman - InfoThe Volvo 850 shares the same ABS setup as the vr6Quote: "These suffer from control unit breakdown resulting in pump out of tolerence or wheel-speed sensor fault codes. Common applications and part numerbers listed below, but we can repair all part numbers from all vehicle manufacturers."http://cgi.ebay.co.uk/Volvo-850-ABS-Controller-VW_W0QQitemZ150128427599QQihZ005QQcategoryZ10432QQssPageNameZWDVWQQrdZ1QQcmdZViewItem BBA Reman - Ebay listing Link to post Share on other sites
Mr_GTI 0 Posted June 17, 2007 Report Share Posted June 17, 2007 if you fit a new control unit does this have to be set up with VAG COM as I read somewhere you have to operate the abs in a certain order to complete the fitting correctly.I also have a control unit fault, I thought I'd try a relay first so bought one from VAG but its totally different to any others in the fuse box area, The new relay is number 79 with 5 pins is there another location for the abs relay? Link to post Share on other sites
VR6Rich 3 Posted June 17, 2007 Report Share Posted June 17, 2007 Yeah it will need recoding when fitted and also the brakes will need bleeding which can be done using VAG-COM too. Link to post Share on other sites
