Car (golf mk3 vr6) was very tappety yesterday, checked oil and it was dry as a bone. Doesn't it give a warning when the oil is low? Apart from sounding like a diesel!!!! Engine is fine now I filled it up with Synta.
Cheers Jez
The oil buzzer only sounds when you have low oil pressure. This is quite normal and the same on most cars (I agree it is odd they didn't employ one that uses oil level as that would be far better). You don't ever want to hear the oil warning buzzer! Serious engine damage can be caused if you have low oil pressure. Main thing is to check it regularly every two or three weeks.
