petay 0 Posted June 22, 2007 Report Share Posted June 22, 2007 I have a 1995 golf vr6 and when the car is cold or has been in gear a while like on motorway journeys the clutch will only come about half way back up when relaesed and won't go into another gear. This makes it very difficult to get gears but when i pump the clutch a few times it seems to start working normally again. Just wondering if anyone else has experienced this or know what it might be? Link to post Share on other sites
finny 0 Posted July 6, 2007 Report Share Posted July 6, 2007 I had this problem with in my Mk2 2.9 Vr, replaced the clucth slave cylinder and this did the trick Link to post Share on other sites
philbatesvr6 0 Posted July 6, 2007 Report Share Posted July 6, 2007 yea i was going say check the slave is working properly but also when was the last time you changed the cuthc fluid ? colud be worth cheacking the level Link to post Share on other sites
petay 0 Posted July 9, 2007 Author Report Share Posted July 9, 2007 just had the clutch fluid changed so it cant be that. Link to post Share on other sites
Frankieboy97 0 Posted July 19, 2007 Report Share Posted July 19, 2007 I had a similar problem...check to see if the fluid is low..i found out i had a slow leak that caused my fluid to disappear alolng with my clutch Link to post Share on other sites
