6cyl_si 0 Posted June 27, 2007 Report Share Posted June 27, 2007 Oh dear!!!!Right i have a '97 mk3 golf vr6. I had an advisory on the bushes on last years MOT, so i decided to do them this year before it got tested. I did the ones on my mk2 golf so went ahead and got the powerflex bushes for the 5 stud hub cars and stripped the car down. Great - I had the beam off the car and the old bushes out in a couple of hours.I came to fitting the bushes and as per the instructions they just slid into the beam. Offered the beam back up into the brackets on the chassis and it wont go back in. If you get the bush in the bracket on 1 side, the other is out by about 10mm.I have piccys somewhere ill post em l8r.Now i dont really want to loosen the brackets on the chassis as i shouldnt have to. I have also spoken to powerflex and got the dimensions for the bushes and they seem to be about right.I have also got some standard bushes and compared them to the powerflex ones and if you line the radi up then the power flex one is different by about 3-4mm.So has anyone else encountered problems whilst trying this???Or does anyone have any ideas or help??Powerflex have come back with 'its a problem with your car' well they would do!!!!Thanks.Si Link to post Share on other sites
cabrioman 6 Posted June 27, 2007 Report Share Posted June 27, 2007 oh rite well im goiun to be doin mine this weekend at work so i hope it dont go liek that i think il get some standard one too just in case ... ill let u know how it goes Link to post Share on other sites
efil4sbuD 0 Posted June 29, 2007 Report Share Posted June 29, 2007 Sorry mate, i can't help you with this but i'm fishing for some info.I have some Powerflex bushes for my Corrado but i took one look at the beam and decided that i might not be able to do it. I couldn't see how to get the new bushes in, is it from the bottom or beam off and slide in from the top?The bottom of my beam where the bush sits is curved and no way a bush is going in that way.I would say that the Powerflex ones look big and maybe they need to be compressed and squeezed in.James. Link to post Share on other sites
VR6Rob 0 Posted June 29, 2007 Report Share Posted June 29, 2007 did you remove the sleeve with the old bushes?this needs to come out befor fitting the powerflex ones. It looks like its part of the beam but its part of the OEM bush Link to post Share on other sites
6cyl_si 0 Posted July 1, 2007 Author Report Share Posted July 1, 2007 Yes when i burnt the old rubber out i went in with a hacksaw and cut the steel outer.They fit in the beam ok, and will fit in the bracket on the car, but when in the beam they wont go!Here are the piccys..As you can see with the other side in the bracket this side is out by what 8 - 10mm..... Link to post Share on other sites
6cyl_si 0 Posted July 1, 2007 Author Report Share Posted July 1, 2007 Here is a standard bush compared to the powerflex one when the radi are lined up, you can see the difference in height.The bushes are the same overall length but where the radius starts is different. This one show the difference in where the radius starts when the bushes are placed on end next to each other. Link to post Share on other sites
ventovr6essex1 0 Posted July 1, 2007 Report Share Posted July 1, 2007 yep i had the same thing they will go in took me ages 2 people to trolly jacks lots of copper slip and even more swearing lol Link to post Share on other sites
purple highline monster 0 Posted July 1, 2007 Report Share Posted July 1, 2007 BIGGER HAMMER is all i will say...and a handfull of F***ks Link to post Share on other sites
gav_113 0 Posted July 1, 2007 Report Share Posted July 1, 2007 does doing the rear beam bushes help alot? i thinking of doing mine, rear always feels all ova the place... Link to post Share on other sites
Jimbob77 0 Posted October 24, 2020 Report Share Posted October 24, 2020 Help... I have just come up against the same problem as the first post from 6cyl_si how the hell do you get them back in ? Do i adjust the hanger brackets both sides to fit them back in or is that a big no no. With them being 10 mm out i cant see how its possible without adjusting the hanger brackets they have ovals in them for adjusting right?? Link to post Share on other sites
