HELP ADVICE NEEDED
Guest 6DOVES
Guest 6DOVES
Hi Guys this might be a dumb question to ask some of you however I am clueless :$ with motors just specialise in sound! I just had my head redone, would I need to have the car Dyno Tuned?
If it was just gas flowed mate, I really don't see any need for any kind of tuning. However if you had three angle valve seats, bigger valves, wild cams etc. then yes a map would need to be done.
I would only guess that the engineers have performed a mild port flow, which will help the engine breathe better and you may notice some response improvement.
