car wont idle very well but its internittant ? error code 00533
well i whent to move me car at work today and it didnt feel right when it was ticking over so i thought nothing of it and put it back where it was until home time,
came to start me car and it would start at all, had a quick look under the bonnet and found that my breather pipe on the back of the rocker cover had broken off so i removed it and replaced it with a bit of rubber pipe and blocked up the vacume pipe and tryed it again , still no luck,
so i whent and got our tech2 and plugged it in and it threw up erroe code 00533 air idle controll volve and 00258 (i think) controll valve relay,
so i cleared the fault memory and it was ok until i got 75% of the way home and when i stop in traffic it started doing it again!
so i it worth me jus replacing the icv ?also does any one no how much it is roughly
thanks for the help peeps
iv phoned psi tunning today they said on the later electric motor tyep throttle bodys that they get a build up of shit in em and it carnt calibrate its self properly thats wat the fault code was saying the throttle idle control sensor oit of tollerences ,
so alls i need do is take it off anf clean it up
