Im awaiting delivery of some 100w xenon-a-like bulbs i found on ebay be having done some reading up im a bit worried now,
Do you lot think that the wiring on a mk3 will take 100w bulbs or should i expect melted wires like in some mk2's.
you can make your owm looms with heaver wiring just use the normal wire as a signal wire and use a relay that can handle the load for both dip and main beam . if you dont want to do this i would unplug your dim dip resister as you will probably burn the bulbs out if you leave the sidelights on for any lenght of time
