  • 3 weeks later...
Im running the vr lump in a mk2. I have found that the sump is sctatched a bit but ok however its the sump plug that gets all the battering as it sticks out lower than the bottom of the sump. after replacing it several times it now wont seal. Ive welded up the old sump plug hole and relocated it to the side of the sump, still low but unscrapable. Then I welded a 4mm s/s skid plate to the bottom of the sump. If you can do this or know somebody who can do it, it will only cost a new sump gasket.
  • 2 years later...
