I have the Konigsports on mine wuith 16" rims,
The car is still fairly comfortable - the only time it gets caught out is on compression sometimes say when travelling across a short sharp dip in the road but other than that they are great.
The speed you can carry into corners is ridiculous :o
Mine are set with 50mm left of travel below the spring seat - you would not want it any lower as it is the right side of sensible at the mo. - ie you can still go over speed ramps with some care etc...
Heres a pic for ride height/wheel size purposes:-
