I have a small leak coming from the front of my auto box, it is starting to cover the underside of the protective guard. having removed the guard and taken a look, it appears to be leaking from what i assume is a breather half way up the front underside of the box. Is this a breather? Can it be removed simply and the 'o' ring or seal be changed easily. What is the procedure for refilling the box or topping up?? Help!! x) x)
