Oil Pressure and Temp gauges
Hi guys,
I've got the above gauges to wire into my 2.8 VR. Where is the best place to put them?
I think for the oil pressure i can use a 1/8 T-Piece to share the original pressure switch feed? Either ok to use as there are 2?
For oil temp, i've got an adapter which i think can be used to replace the sump plug, not sure i really like the idea of that though. Does it work ok? Liable to be damaged easily? Can i use another T-Piece on the temp sender on top the filter housing?
any help appreicated, esp links to correct t-pieces
thanks
  • 2 years later...
