VR6_ROB 0 Posted September 24, 2007 Report Share Posted September 24, 2007 hi all need some advice before i rip my engine aparti have a 2.9 vr6 engine in a mk2its been in just over a monthnow when i drive steady the water level is great does not movebut if i drive it hard its loosing water i cant see any leaks anywherebut i noticed the hoses go really hard full of pressurei been told it could be headgasket issue?the oil and water are not mixing so i was just wondering if it could be somethingstupid or if anyone has come across thishelp would be appreciated cheersrob Link to post Share on other sites
M4VTY 0 Posted September 24, 2007 Report Share Posted September 24, 2007 Either a head gasket or your thermostat get's stuck open. try changing the thermostat that's the chaper option. Link to post Share on other sites
VR6_ROB 0 Posted September 24, 2007 Author Report Share Posted September 24, 2007 I have just changed that few weeks ago but it was doin it before then Link to post Share on other sites
MaidenVR6 26 Posted September 24, 2007 Report Share Posted September 24, 2007 When your water pump is finished, it starts to leak water. Check that. Remember that the water system on a VR6, is a common problem. Link to post Share on other sites
craggsy 91 Posted September 24, 2007 Report Share Posted September 24, 2007 If you changed your thermostat did you crack the housing putting it on. As it won't leak under pressure but will when stationary Link to post Share on other sites
VR6_ROB 0 Posted September 25, 2007 Author Report Share Posted September 25, 2007 it leaked before the thermostat was fitted they is no signs of leaking when it is stationaryi can plod about normal and it will be greatas soon as i hammer it the water goes downwould the pump leak under pressure? Link to post Share on other sites
mannie 0 Posted September 25, 2007 Report Share Posted September 25, 2007 How much water are you losing ? And you have replaced all the seals in the thermo housing ? Link to post Share on other sites
rodney 17 Posted September 25, 2007 Report Share Posted September 25, 2007 You have a couple of options really. Does it happen when you rev or when under driving load only???Does the water level in the expansion tank alter as you rev it???What I am trying to understand is if you have a blockage (maybe air) somewhere which could be working its way out. Or if you have a pinprick somewhere on a hose or gasket which causes the leak under pressure. Usually if it is things like the water pump it is very obvious as a leak under the car.Don't forgeet to look at the connections into the heater as well as they flow through that way also.The very solid pipes does hint at the pressure building and remaining.Hope it helps Link to post Share on other sites
gloster 0 Posted September 25, 2007 Report Share Posted September 25, 2007 A look at this thread may help you, as this all sounds terribly familiar to me...http://www.vr6oc.com/e107_plugins/forum/forum_viewforum.php?119 Link to post Share on other sites
VR6_ROB 0 Posted September 26, 2007 Author Report Share Posted September 26, 2007 it only leaks when driving hard the hoses are rock hardi have emptied the water twice and bleeded itdoes not looses a drop when i drive about normallynot sure on the water level moving when reving itmy top and bottom rad hoses are not the right lengththey are to short so they is a pipe inside with another piece of hose attatched all jubilee clipped upthe bottom hose has popped off before and it was leaking there the other week so i refitted iti have samcos on orderthe link does not work Link to post Share on other sites
gloster 0 Posted September 26, 2007 Report Share Posted September 26, 2007 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?153370I must've got the wrong link... try this one. Link to post Share on other sites
rodney 17 Posted September 26, 2007 Report Share Posted September 26, 2007 you have a PM VR6 Rob Link to post Share on other sites
Giles 0 Posted September 28, 2007 Report Share Posted September 28, 2007 Try checking your water pumps dude. I have the exact same symptoms (losing water, rock hard hoses, etc.) and both of my water pumps (electric AND mechanical) are goosed. It's in on Monday for new items.Take off a coolant hose and see of there's any water flow with the engine running.Hope this helps... Giles. Link to post Share on other sites
VR6_ROB 0 Posted September 28, 2007 Author Report Share Posted September 28, 2007 you have a PM VR6 Rob I dont loli have changed the electric pump a few weeks back as mine was goosedwould the water not leak everywhere if it was the pump?in a way i hope it is the pump as its easier to do then a headgasket i thinkis they any signs of them breaking Link to post Share on other sites
VR6_ROB 0 Posted October 7, 2007 Author Report Share Posted October 7, 2007 i fitted my samcos and the pipes aint pressured up like before and nothing is leakingstrange Link to post Share on other sites
