i have recently bought a vr6! when the engine is started i can hear wots like a tappin or knockin coming from the top left hand side of the engine- cyln 1! i have takin the rocker off and everything seems to be fine! the car has 58000 on the clock and is currently not on the road! any help would be appreciated!
Has the car been off the road for a while?
How heavy sounding is the tapping noise? Is it a tapping or a knocking?
If it hasn't been driven for a while and its a noisy but 'light' sounding tap then it might just be an empty tappet - it should stop once the oil warms.
cheers guys! do u think its worth takin the cams out to do? the car has been off the road for 3 years but this is the reason why the previous owner put it off the road! is sounds like a loose tapping but i goes away just over 1000rpm and comes back again? goin to give it a good service and see how it goes!! cheers
Am i correct in saying that if it was the chains and guides that the noise would get louder with the engine?
No I don't think so. They seem to rattle at about 1200rpm as that's probably between what the spring can easily hold and before the hydraulic bolt pressure is taking up the tension.
At idle mine's completely silent chain wise and the same from approx 1600rpm up.
Could just as easily be tappets though as mentioned.
Try flushing/diesel oil cleaning/switching to synthetic whichever takes your fancy to remove any deposits likely to be affecting oil flow. Ordered in terms of strength of cleaning (detergent levels).
