volkmen 0 Posted September 24, 2007 Report Share Posted September 24, 2007 Hi does anyone know if the auxillary water pump should run after the engine is shut down the same as the golfs cos mine doe'snt, the pump is fine as i have already tried a knew one.if it should run is there a seperate relay and where is it? Link to post Share on other sites
xyber 1 Posted September 24, 2007 Report Share Posted September 24, 2007 it only runs when the engine is hot enough to warrant it i think mate Link to post Share on other sites
volkmen 0 Posted September 25, 2007 Author Report Share Posted September 25, 2007 Cheeers bud, it was a funny question to ask i know but the last thing iwant is more repairs especially another head gasket. the pump was'nt the cause that time neither. I'll get it good and hot and test it again. ta Link to post Share on other sites
kilokilla 0 Posted November 10, 2007 Report Share Posted November 10, 2007 the auxillery pump should run same as the golfs and if pump is ok its probably down to the black box unit that sits just in front of your water expansion tank mate as this controls your rad fans and auxillery water pump. Link to post Share on other sites
daleyboyVR6 6 Posted November 11, 2007 Report Share Posted November 11, 2007 i belive it should go on if the water temp is 82 degs c or above so really should be on after most journeys......................... :-p Link to post Share on other sites
volkmen 0 Posted November 16, 2007 Author Report Share Posted November 16, 2007 Thanks every peeps looking into it,might need to replace that little black box. cheers again. Link to post Share on other sites
