I just had this..
Where the flexible fuel line meets the 'thinner' line on the bracket that is attached to the offside suspension turrent (this is a common area to give way and cause the fuel smell..)
Simply undo it, rid of the dodgey VW clip, if needed, cut the pipe a little bit then use a jubilee clip to re-attaches pipes..
Thing is, I cud never see the fuel as it evaporated so quick, but lucky had a lok when engine was running and saw the leak..
U may have the same prob..
