Damien. 0 Posted October 1, 2007 Report Share Posted October 1, 2007 I know its the wrong part of the forums, but i dont think no one noticed this in the Gearbox and transmission section.Anyway, after leaving my car stand for a short ammount of time then goto drive it again im getting problems with the clutch. When i first get into the car the clutch pedel will just go straight to the floor as if the link between the pedel and clutch itself is broken, Ive goto "pump" the clutch for it to work again properly. Alot like when you get air out of the brake system.Any ideas what the problem is ? Link to post Share on other sites
mannie 0 Posted October 1, 2007 Report Share Posted October 1, 2007 No harm in bleeding your clutch cylinder to see if you have air ,are your brakes ok ,check your brake fluid level too . Link to post Share on other sites
Damien. 0 Posted October 1, 2007 Author Report Share Posted October 1, 2007 Where do i find the clutch cylinder please ? Link to post Share on other sites
Dave Lea 4 Posted October 1, 2007 Report Share Posted October 1, 2007 on the top of the box below the battery Link to post Share on other sites
Damien. 0 Posted October 1, 2007 Author Report Share Posted October 1, 2007 Thanks alot, if it needs topping up or anything how do i do that ? Sorry for all the questions. Link to post Share on other sites
Lizard Racing 0 Posted October 1, 2007 Report Share Posted October 1, 2007 Just fill the brake reservoir up. The clutch shares the same resrvoir. You will need to bleed the clutch though by the sounds of it. Link to post Share on other sites
mannie 0 Posted October 2, 2007 Report Share Posted October 2, 2007 Thanks alot' date=' if it needs topping up or anything how do i do that ? Sorry for all the questions.[/quote']Here's what the Brake reservoir look like (under the car bonnet)and the Clutch cylinder above the gear box (also under the car bonnet) Link to post Share on other sites
Damien. 0 Posted October 2, 2007 Author Report Share Posted October 2, 2007 Excellent, thanks for the help. Ill bleed it tonight and let you know if that sorts it. Thanks again. Link to post Share on other sites
