Rough Engine at idle and Accelerating at Low RPM - Please assist asap
I got my spark plugs changed very recently. The second day the car developed rough engine at idle (rev needle does not move), sounds like it is choking.
And accelerating at low RPM causes the car to stutter. Above 3000rpm it is fine.
Now, I noticed the oil was alarming low and have now topped it up.
I have to wait to get some time off work to take it back to the garage that did the spark plugs.
It is likely to be a spark plug problem? or is the engine damaged from low oil?
Car is a 12v VR6 96, low miles.
Returned to the garage this evening and said it wasn't firing properly at idle and low revs.
We walked outside and I was holding the wire removal tool in my hand and mentioned that I had the special tool if he needed. He glanced at the engine when it was running and he could tell which plug was causing the problem, and he then yanked the plug out of the engine by pulling the lead - (Hands on Head! -yikes)
He then pushed it back in with a flat edge screwdriver.
Car is running fine now. I know that the wires are actually original, 66 thousand miles. They are holding up well, even after that abuse!
Thank you for your replies
