After market management
Who's running after market management, and what you using.
Now im running 12psi with the charger and wih out Maf & Isv the running bit up and down and cold
start bit of a nite mare, I think this is only way forward
Im looking into the Emerald system, just interested in good or bad reports about it.
how much is this mnagement fitted and mapped??
im looking to run about 11psi turbo, and getting it mapped in couple of weeks just keeping my options open at the mo, at the moment im thinking stealth standard mangement.... will work out about 4-500 with petol money going there and back....
Vince did a Golf VR turbo map ages ago and it made 350hp @ 10.5psi. Quite impressive. A good alternative if the Standalone is a bit much for you.
