Hi Guys
My 98 make`s a ugly grr -grr noise on start upbut goes quite after 5 sec and the motor is getting louder every day. I took the oil filter off and saw small metal pieces. I took the car off the road. What do you guys suggest what must i do.Today i`m gone check the belt tensioner and if it not it i`m gone drain oil and drop the sump for further investigation. If the big-ends are gone can i just replace them????
How's it! Good to see some more south africans on here! (lived there for a year when I was 15 years old, loved it!)
Sounds like you've got a serious problem there mate. Possibly not the big end bearings. There'd be knocking if they'd gone. Possibly your oil pump, however if I were you I'd look into a full bottom end re-build as if there's metal in the oil then there'll be metal in all of the joints/bearings which will end up dying in the not too distant future. Everything else will be at risk too, so a full engine rebuilt might be a good idea. Bit more expensive, but that way you know everything's all OK.
Whatkind Boet, great to see some fellow SA members on here, miss SA alot :-( Very Sick, my sypathies are with you man! I guess that is how you came about with "very sick" as your nick? Anyways good luck......Oh yeah Go springboks.......maybe this weekend it will be 50...nil??? :)
