Very Sick 0 Posted October 15, 2007 Report Share Posted October 15, 2007 Hi GuysMy 98 make`s a ugly grr -grr noise on start upbut goes quite after 5 sec and the motor is getting louder every day. I took the oil filter off and saw small metal pieces. I took the car off the road. What do you guys suggest what must i do.Today i`m gone check the belt tensioner and if it not it i`m gone drain oil and drop the sump for further investigation. If the big-ends are gone can i just replace them???? Link to post Share on other sites
adam_christie 0 Posted October 15, 2007 Report Share Posted October 15, 2007 How's it! Good to see some more south africans on here! (lived there for a year when I was 15 years old, loved it!) Sounds like you've got a serious problem there mate. Possibly not the big end bearings. There'd be knocking if they'd gone. Possibly your oil pump, however if I were you I'd look into a full bottom end re-build as if there's metal in the oil then there'll be metal in all of the joints/bearings which will end up dying in the not too distant future. Everything else will be at risk too, so a full engine rebuilt might be a good idea. Bit more expensive, but that way you know everything's all OK. Link to post Share on other sites
amazak 3 Posted October 15, 2007 Report Share Posted October 15, 2007 Whatkind Boet, great to see some fellow SA members on here, miss SA alot :-( Very Sick, my sypathies are with you man! I guess that is how you came about with "very sick" as your nick? Anyways good luck......Oh yeah Go springboks.......maybe this weekend it will be 50...nil??? Link to post Share on other sites
Very Sick 0 Posted October 17, 2007 Author Report Share Posted October 17, 2007 Hi GuysI dropped the sump and found that the big-ends was on there way out. The problem was that the previous owner knocked the sump and it blocked the oil-pump intake and damaged the pump. I`m gone fit knew big-ends and oil pump check how it`s going. Link to post Share on other sites
adam_christie 0 Posted October 17, 2007 Report Share Posted October 17, 2007 Oh sh1t. Might have the same problem then. My sump's a bit battered too. How close to the bottom of the sump does the oil pump sit? Does it sit right on it or is there a gap? My car sounds a bit cack on start up when it's cold too...... :-( Link to post Share on other sites
