woodz77 0 Posted October 23, 2007 Report Share Posted October 23, 2007 i just went to use my car , aint used it since yesturday morning and the thing wont idle ? never had a prob with it yet . i can keep it ticking over by keeping my foot on the acceclerater but as soon as i remove it it dies . i even let it warm right up but still no joy .and ideas what it mite be and is there a way to do afault code read on it ??cheers ! Link to post Share on other sites
S3Graham 0 Posted February 6, 2009 Report Share Posted February 6, 2009 sorry to bring up a dead thread but my car is doing this exact thing?? anybody know what it could be?? it idles below 500 and once warm just stays running but when cold just dies Thanks in adv..Graham Link to post Share on other sites
mattp1983 0 Posted February 6, 2009 Report Share Posted February 6, 2009 mine does the same Comes up with a fault... MAF B+ short to ground...... Changed MAF and checked all wiring, still same fault.... Link to post Share on other sites
Charged VR 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Have you both checked for Intake air leaks or faulty coolant temp sensors?And are your cars OBD 1 or 2? Link to post Share on other sites
mattp1983 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Mine is OBD1, coolant temp sender was a brand new one out of my old digi 8v mk2, same part no... Although makes no difference if you plug that in/unplug it. Intake air leak could be a possibility as I have deleted the carbon canister..... (Its a mk2 conversion) Link to post Share on other sites
Charged VR 0 Posted February 7, 2009 Report Share Posted February 7, 2009 Well worth checking there are no Air leaks. Next to the throttle vale is a small palstic box. These can split and cause unmeterd air in and it wont idle. Link to post Share on other sites
gavinvr6 0 Posted February 7, 2009 Report Share Posted February 7, 2009 mine does similar and stalls at random intervals yet i have no air leaks that i can find, only thing iffy is the throttle position sensor on side of tb only has one screw holding it in. (obd1 golf with rado tb)mat i wouldnt worry about the carbon can as ive removed mine and never had any issues all the time ive had it done, and many others here can probably report the same thing. so long as you block the black pipe off and feed the clear one into the inner wing to vent it you should have no worried with that Link to post Share on other sites
S3Graham 0 Posted February 9, 2009 Report Share Posted February 9, 2009 Mine is a 96 OBD2,Havent checked for leaks yet.... will do that today. As for coolant temp sensor... its started AFTER i've changed the crack pipe and the 2 sender units on-top of the oil filter housing. i guess i could of banged a sensor unit somewhere?? is the green wire to the left of the sender units coolant temp?? Link to post Share on other sites
craggsy 91 Posted February 9, 2009 Report Share Posted February 9, 2009 coolant temp sended is on the thermostat housing not oil filter housing Link to post Share on other sites
Charged VR 0 Posted February 11, 2009 Report Share Posted February 11, 2009 I think the green wire that you are talking about is the oil temp sensor for the MFA display. Are all the connectors aroung the front engine mount connected? Link to post Share on other sites
