ardandy 0 Posted October 26, 2007 Report Share Posted October 26, 2007 Just (trying) to replace the blue temp sensor. I've got the plug off but I can't get the sensor out!Is there something elde I need to do or do I just need to get a pair of pliers to it?Cheers!Andy Link to post Share on other sites
Dave Lea 4 Posted October 26, 2007 Report Share Posted October 26, 2007 have u puld the clip of Link to post Share on other sites
xyber 1 Posted October 26, 2007 Report Share Posted October 26, 2007 take the lid of the res bottle aswel, may help Link to post Share on other sites
ardandy 0 Posted October 26, 2007 Author Report Share Posted October 26, 2007 have u puld the clip ofYeah, the plug is out but the sensor itself is not budging. Just didn't want to get all forceful when it could be something obvious! Link to post Share on other sites
Dave Lea 4 Posted October 26, 2007 Report Share Posted October 26, 2007 there is a u shaped clip that holds the sensor in Link to post Share on other sites
ardandy 0 Posted October 26, 2007 Author Report Share Posted October 26, 2007 The clip holds the plug into the sensor, the plugs out but the sensor remains, Link to post Share on other sites
craggsy 91 Posted October 26, 2007 Report Share Posted October 26, 2007 There should be a circlip that holds sensor in place Link to post Share on other sites
Dave Lea 4 Posted October 26, 2007 Report Share Posted October 26, 2007 try turning the sensor to brake the seal rather than pulling it Link to post Share on other sites
philtvr 0 Posted October 26, 2007 Report Share Posted October 26, 2007 press clip remove plug, now there will be a u shaped clip runiing through the plastic mounting holding the sensor in slide this out to remove the sensor. Link to post Share on other sites
Dave Lea 4 Posted October 26, 2007 Report Share Posted October 26, 2007 well explaind Link to post Share on other sites
ardandy 0 Posted October 26, 2007 Author Report Share Posted October 26, 2007 I'll give that a shot tomorrow when its light! Thanks! Link to post Share on other sites
craggsy 91 Posted October 26, 2007 Report Share Posted October 26, 2007 ANd to think Dave you deal with this every day don't ya Link to post Share on other sites
Dave Lea 4 Posted October 26, 2007 Report Share Posted October 26, 2007 yep easyer doing than saying Link to post Share on other sites
ardandy 0 Posted October 28, 2007 Author Report Share Posted October 28, 2007 Woohoo!Done it and it solved the problem! Cheers! Link to post Share on other sites
james4287 1 Posted January 3, 2008 Report Share Posted January 3, 2008 incidently on mine there was a wiring loom bracket directly above the coolant sensor meaning the circlip couldn't fully come out, 10mm spanner required! Link to post Share on other sites
