Dezmond_vr6 0 Posted October 29, 2007 Report Share Posted October 29, 2007 wat size fan does a vr6 have?mine is jus a single fan, which i think might be off the original engine as iv had a vr6 conversion.iv seen vr6's with twin fans is that normal or jus with the air con?if u could help me out that would be greatmany thanks Link to post Share on other sites
amazak 3 Posted October 29, 2007 Report Share Posted October 29, 2007 Mine has a twin fan but no AC?, so I assume it must be standard to have 2 fans? but I remember someone once mentioning that the earlier models came with one fan? Link to post Share on other sites
clarkie 1 Posted October 29, 2007 Report Share Posted October 29, 2007 na all vr6 came with twin fans 1 with a motor and a belt from 1 to the other to run the 2nd Link to post Share on other sites
Dezmond_vr6 0 Posted October 30, 2007 Author Report Share Posted October 30, 2007 i must have the 2.0ltr fan and prob rad on then!!i'll have to try find rad and twin fan for mine asap then! i cant understan why the guy before me didnt check up on this hes fun it for about four years like this. Link to post Share on other sites
Dezmond_vr6 0 Posted October 30, 2007 Author Report Share Posted October 30, 2007 im not actually sure if the engine thats been put in is a 2.8 or a 2.9 vr6. is there any difference really for buying parts? ir they jus same parts? Link to post Share on other sites
richievr 1 Posted October 30, 2007 Report Share Posted October 30, 2007 as said all vr's had twin fans as std.if you want to put them onto your you will need the front panel too, as they fit into two round recesses in the panel....and you can find out if yours is 2.8 or 2.9 by looking just under the headgasket on the alt belt end.if it is AAA it is 2.8 , if it is ABV it is 2.9... parts are different you will need to know which you have to get any bits for it.. Link to post Share on other sites
Dezmond_vr6 0 Posted October 30, 2007 Author Report Share Posted October 30, 2007 thats ace info mate thanks for that i'll have to take a look and find out wat the situation is. wat do u mean by a front panel? Link to post Share on other sites
richievr 1 Posted October 30, 2007 Report Share Posted October 30, 2007 the black plastic bit the rad mounts into and the headlamps bolt into....... Link to post Share on other sites
purple highline monster 0 Posted October 30, 2007 Report Share Posted October 30, 2007 na all vr6 came with twin fans 1 with a motor and a belt from 1 to the other to run the 2nd eh? mine are both elctric and dont have any belt connecting them as far as i know? thats foord crapri styleeeeee with the link belt job!! Link to post Share on other sites
richievr 1 Posted October 30, 2007 Report Share Posted October 30, 2007 na all vr6 came with twin fans 1 with a motor and a belt from 1 to the other to run the 2nd eh? mine are both elctric and dont have any belt connecting them as far as i know? thats foord crapri styleeeeee with the link belt job!!don't think so :-p will have one powered fan and a little belt to join them together.... Link to post Share on other sites
