vr6 turbo and obd1 managment
just a idea my friend had his std ecu sent off to c2 tuning and basicly ended up sending it back ,as the engine wouldnt right ,so he seems to think hi vr6 will run fine with a std ecu ,36lb injectors,4inch maf houseing,obd2 and turbo kit runing at 9psi without head spacer?
Yeah a few of my friends are runninng vr6's with superchargers ,and close to 300 bhp with a remap on the standard ecu,I might try what some of the other forum members have done and use a rising rate fuel pressure reg . just to get the conversion up and running and then when im happy with everything , go for the bigger injectors and a remap .
ive also just bought my obd1 vr6 which im trying to get at least 400nhp ,can this be done
ive ordered upratted rods
1.5mm hrad spacer,42cc injectors
a std to4e turbo
large race flow intercooler
but im now worryed as mine is the dizzy type ,anything i can ,pleaseany advise avaible just add
That sounds good im looking for around 400 bhp , my previous car was a 16v t golf that i built myself it had 260bhp and did 13.8 quarter mile with loads of wheelspin so im hoping to beat that. the only thing im not sure about is this thing about having a 4" maf housing can someone tell me why that is needed.
Your engine will barely idle with 42cc injectors :-)
42lb you must mean' date=' or 440cc?
400hp easily achievable with that, but it will depend on what management you use etc.
[/quote']right ,im better off not useing these then,,im a little stuck as my 92 vr6 has a dizzy instead of coilpack ,and i dont want to keep buying parts if this wont work on a early 2.8 vr6 engine,im getting told alsorts here so can u or anyone give me the spec i need for at least 400bhp ,as my engines in bits and money ids burning a hole in my pocket cheers,e.g cam/remap/maf/clutch/type/head spacer an turbo etc
