antone28 0 Posted November 3, 2007 Report Share Posted November 3, 2007 Hi, im nearing the end of converting my vr6 to turbo, i was wondering if there are any big disadvantages with having the standard ecu remapped,I know stealth can do it for me ,but would it be worth spending a bit more money and get an emerald system or similar Link to post Share on other sites
powernut 1 Posted November 3, 2007 Report Share Posted November 3, 2007 just a idea my friend had his std ecu sent off to c2 tuning and basicly ended up sending it back ,as the engine wouldnt right ,so he seems to think hi vr6 will run fine with a std ecu ,36lb injectors,4inch maf houseing,obd2 and turbo kit runing at 9psi without head spacer? Link to post Share on other sites
antone28 0 Posted November 3, 2007 Author Report Share Posted November 3, 2007 Yeah a few of my friends are runninng vr6's with superchargers ,and close to 300 bhp with a remap on the standard ecu,I might try what some of the other forum members have done and use a rising rate fuel pressure reg . just to get the conversion up and running and then when im happy with everything , go for the bigger injectors and a remap . Link to post Share on other sites
powernut 1 Posted November 5, 2007 Report Share Posted November 5, 2007 ive also just bought my obd1 vr6 which im trying to get at least 400nhp ,can this be done ive ordered upratted rods1.5mm hrad spacer,42cc injectorsa std to4e turbolarge race flow intercoolerbut im now worryed as mine is the dizzy type ,anything i can ,pleaseany advise avaible just add Link to post Share on other sites
FishWick 21 Posted November 6, 2007 Report Share Posted November 6, 2007 Your engine will barely idle with 42cc injectors :-)42lb you must mean, or 440cc?400hp easily achievable with that, but it will depend on what management you use etc. Link to post Share on other sites
markiev6 1 Posted November 7, 2007 Report Share Posted November 7, 2007 my obd1 turbo is running 500bhp on a remapped vr6 ecu !! 19 psi with 440cc injectors and runs well no missing and idles fine all depends who you get to do your remap!!! Link to post Share on other sites
antone28 0 Posted November 7, 2007 Author Report Share Posted November 7, 2007 That sounds good im looking for around 400 bhp , my previous car was a 16v t golf that i built myself it had 260bhp and did 13.8 quarter mile with loads of wheelspin so im hoping to beat that. the only thing im not sure about is this thing about having a 4" maf housing can someone tell me why that is needed. Link to post Share on other sites
antone28 0 Posted November 7, 2007 Author Report Share Posted November 7, 2007 also who did your remap Link to post Share on other sites
markiev6 1 Posted November 7, 2007 Report Share Posted November 7, 2007 you will need a 4" maff its so you can get more air flow round the senser, i started off with 3" and it just over fueled badly ill speek to my mate and find out if he still does the map for obd1 Link to post Share on other sites
antone28 0 Posted November 7, 2007 Author Report Share Posted November 7, 2007 ok, thanks. is it just the maff housing that has to be 4 " or is it the pipe work after it aswell. Link to post Share on other sites
antone28 0 Posted November 7, 2007 Author Report Share Posted November 7, 2007 Ok i just did some research and i fully understand what the 4" maff housing does now or any other alteration of the size of the maf housing. Link to post Share on other sites
powernut 1 Posted November 9, 2007 Report Share Posted November 9, 2007 Your engine will barely idle with 42cc injectors :-)42lb you must mean' date=' or 440cc?400hp easily achievable with that, but it will depend on what management you use etc.[/quote']right ,im better off not useing these then,,im a little stuck as my 92 vr6 has a dizzy instead of coilpack ,and i dont want to keep buying parts if this wont work on a early 2.8 vr6 engine,im getting told alsorts here so can u or anyone give me the spec i need for at least 400bhp ,as my engines in bits and money ids burning a hole in my pocket cheers,e.g cam/remap/maf/clutch/type/head spacer an turbo etc Link to post Share on other sites
