Boring (but swift) Tyre Size Question...
I have a standard VR6.
I want some 16" wheels.
Seen some, but they have 205 / 50 / 16 tyres.
Do you think the aspect ratio of 50 will fit with no rubbing? My car is not lowered. It would be great if they did beacuse they're good tyres, and obviously it would be nice not to have to fork out for four new ones.
Thanks.
Not a specialist on the subject but they should fit... only problem is it will change the outer diameter so will put your speedo out, all be it slightly?
Used to be a tyre calculator thingy on here but wasn't working last time I went to use it.
Hope this helps.
Thanks. I realise that a 4-0 or 45 ratio would be best. It's just that the tyres are good quality Yokos wth a fair amount of tread, and it would be great to be able to use them, even just for a couple of months. The other option would be to replace my two front tyres at the moment, but if I could get these 16"s to work that would be great. The Speedo thing is certainly an issue to take into consideration. Would I have to always watch I was driving UNDER the limit?
On the MK3 you will need 205/45/16, it goes like this....
205/50/15
205/45/16
205/40/17
For every inch you go up in alloy size you will have to reduce the tyre ratio by 0.5. They will catch on the shocks. I recently attempted putting 225/45/17 's on my vr and the rears caught at the shocks. So in theory it is the same thing as you have 16" but the tyres are 50 profile.
