Converting: OBD 1 To ODB 2
depends on how much you can find the parts for, some people spend 500/600 pounds + labour, then 350 + VAT for shrick cams and a remap and probably dont see 20bhp so if you can find the lot off a written off vr6 for few hundred quid id say its defo worth 20bhp.
also, for future referance if you plan on doing anything else to the car like SC, obd2 management will respond to it alot better especialy when its remaped...
and dont forget in order for obd2 ecu to work you will need the ecu/transponder box/and key chip all from the same car
just get yourself a big bore throttle body(obd1 only)
pm kevhaywire on here and he'll put u onto the guy that sells 'em' date='then get the car remapped unless your planning other mods 1st
The guy your looking for BBTB is Ian is email is alpina527@aol.com great guy he will sort you out.
Depends how much power your going, if your going big power go standalone. Emerald is £580 thats the way i've gone.if you need fitting,loom, mapping its about £1200.
