cable change?
the gear selector thing on my gearbox snapped. so i got another one.. its the bit the cables bolt to to change gear.. ive fitted it, and it works ok, but is a bit notchy going in 5th? ive noticed there is adjustment where the cables bolt to it..
so can anyone tell me the correct way to set it up, do u just leave the bolts loose and put it in a certain gear to line it up and the tighten it all up?? cheers peeps
