c2 motorsports
i was told that the obd2 system would only work up to about 10 psi ' date='how does c2 get it to work with 18
What C2 say is the software is mapped for 17psi of boost and if you are going to run more than that
do it on a dyno and check your fueling !
I have seen a couple of cars doing 22psi with C2 software and mine was fine at 19psi and will run more boost
soon !
Here is a link email them and ask for Nate he bent over backwards to help me top bloke !
They suplied my Ecu Injectors Spacer plate 4"maf and C2 software
http://www.ngpracing.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=c2motorsports
The C2 42lb code with 4" MAF body should be good for 18psi' date=' maybe a little more.
If you have an OBD2 ECU, you'll need to send it off to C2, or import a US ECU.....but I'm not sure if the wiring is the same. I'm looking into myself.
And i have a US ecu and it works fine !
C2 Mototsports does have a UK arm now
If you guys have any queries please dont hesitate to PM me on here
We have developed UK software versions, and they run very well,
Ive been trying to ring them but know one answers
Remember Chris is 5 hours behind us, and at the moment he is the busiest man on the planet with the release of the C2 Motorsports R32 turbo kit.
The C2 motorsports UK website will be up and running soon, and products can be purchased through this gateway.
Is it possible to buy just the chip and get someone here to solder it in
No C2 said there is some software in a US ecu that aint in ares !
The ecu he sends you wont have a chip in it either he must flash the map on to it !
Just get him to suply one he dont charge alot it would cost more to buy a spare over here and post it to him !
We have been working on setting up a UK based division of C2Motorsports in order to better service our VW customers across-the-pond. Our full line of C2Motorsports products will be available, as well as our European developed software specifically for your cars.
Please feel free to contact C2Motorsports.co.uk at: sales@c2motorsports.co.uk
