JohnnyP 0 Posted November 28, 2007 Report Share Posted November 28, 2007 Hi my vr6 is occasionally cutting out when approaching junctions i.e you come down the gears then when in neutral just before stopping it cuts out. Starts again fine. Has never idled smoothly since i've had it - checked all the idle valve pipes and MAF sensor appears clean so I'm after a VAGCOM cable. Only thing is its OBD1 with the two plugs - all the ones on ebay are obd2 so any suggestions where to get one? Also any suggestions on remedy for the problem i'm having? I'm thinking a position sensor of some sort......thanks Link to post Share on other sites
vimtovento 0 Posted November 28, 2007 Report Share Posted November 28, 2007 You can get them from here they convert OBD1 to OBD11 http://www.skpang.co.uk/catalog/product_info.php?cPath=21&products_id=143 Sukkin is a nice bloke i used to work with him..Phil Link to post Share on other sites
kilokilla 0 Posted November 28, 2007 Report Share Posted November 28, 2007 Usually this prob is down to throttle body needing a good clean but it could also be your idle stabilisation valve which sits just to the right of throttle body mate .Carl. Link to post Share on other sites
JohnnyP 0 Posted November 29, 2007 Author Report Share Posted November 29, 2007 nice one cheers guys Link to post Share on other sites
vr6g 0 Posted November 30, 2007 Report Share Posted November 30, 2007 I had the same problem mate, cleaned my Airflow meter and replaced the cam position (hall) sesor, ran sweet after that!!! Link to post Share on other sites
