Removing front grille
I want to remove the drivers side headlight, how do you get the bottom piece of the front grille off? I have unclipped the top part but can't figure out the rest. I don't want to snap any clips.
Also is it normal to have condensation inside the headlight lens?
Get a flat head srcew driver, neel down by the front bumper. If you look in the gap between the bottom of the grill and the top of the bumper you should see some clips (vertically inline with the middle of the headlight). Stick the screwdriver in and pop the clip. I think there is two clips under the headlights and the middle part of the grill just lifts up and out after you undo the two clips.
Don't know about the condensation, but i've got the same problem with one of my rear m3 lights. It's abit wierd cause the other one is alright. Mite be because the light is not bolted in tight enough or something.
