Is it the rear or front passenger?
Front
check pollen filter under rain tray for blockages all sunroof drain holes and the drain holes in the door hinges. The check membrane on door, behind door card, door rubber seals are seated correctly, also could be heater matrix :( , mine did this when leccy windows developed a fault and would open slightly without me realising.
back
rear light cluster seals, and as above
