c11rgd 0 Posted January 19, 2008 Report Share Posted January 19, 2008 R reg Highline totally standard apart from Magnex back boxthe car has had a major service inc plugs oil etcwhen running its like a bullet, solid and consistent never misses a beat, but over the past few days these are the symptons1. the car will just cut out randomly, just the engine, lights everything else comes on etc2. when trying to start it again it cranks over but doesnt fire up.3. then after leaving it abit it does, but at the mo its not starting.4. it has a cat 1 alarm and immobiliser built into hte phob, and its full closure. will get the make.5. Started teh car after a couple of hours, i think its ok once it cools down, if that makes any sense?6. only other thing wrong with it is the engine mounts need changing. can this affect anything?Some one please help, where is the OBD port? and anyone know what this maybe. Link to post Share on other sites
Dave Lea 4 Posted January 20, 2008 Report Share Posted January 20, 2008 get it code read ...sounds like crank sensor codes will tell u more Link to post Share on other sites
c11rgd 0 Posted January 20, 2008 Author Report Share Posted January 20, 2008 here are the diagnostic read outs. turns out it was the crankshaft position sensor. does anyone know where this is. Link to post Share on other sites
StuartVR6 0 Posted January 21, 2008 Report Share Posted January 21, 2008 Hi The cam Position (Hall) Sensor is on the Right hand side of the engine as your looking at it, above the Coil Pack. Its a small Triangular Sensor.Part No 021 907 601 AI just got one for mine £42.00 from Volks.ThanksStuart Link to post Share on other sites
c11rgd 0 Posted January 21, 2008 Author Report Share Posted January 21, 2008 Thanks Stu, i found it just before reading your post, alot of peeps have said to clean it etc, so i did but havent put it back in yet, do you think its worth doing this or should i just fork out the £40 Link to post Share on other sites
StuartVR6 0 Posted January 21, 2008 Report Share Posted January 21, 2008 Hi, I cleaned mine a while ago seemeed to work fine. I just figured as this was the second time it had this fault to get a new one, hopefully it won't happen again! Link to post Share on other sites
c11rgd 0 Posted January 21, 2008 Author Report Share Posted January 21, 2008 I am Well P***** OFF, just bought a new one and the car cut out again!!! AAARRRGHHHH! anyone please tell me what to do did i replace the right part, i changed the one stuart gave me the part number for. Link to post Share on other sites
jezmoz 0 Posted January 21, 2008 Report Share Posted January 21, 2008 have you checked the battery? Link to post Share on other sites
c11rgd 0 Posted January 22, 2008 Author Report Share Posted January 22, 2008 all terminals on the battery are nice and tight, the lights all stay on! its just not starting, and then after around 15minutes it does. just the engine cuts out!!Stu i noted you call it the CAM hall sender is this not different to the Crankshaft sensor which i am looking for and is listed here!http://www.thephirm.co.uk/Pages/faq.html#mk3_mk3ok so i think ive changed the wrong one! ive changed the CAM sensor and not the CRANK!the error code i had was *** Engine Speed / Reference Sensor (G28) ***Engine speed and crankshaft position are registered by a single sensorlocated on the engine block.The sensor reads a toothed wheel mounted on the crankshaft to readengine speed.The toothed wheel has a two-tooth gap which is used as the measuringpoint for the crankshaft position.which refers tohttp://forums.vwvortex.com/zerothread?id=2934505can someone confirm the part number? is it 021 906 433 C Link to post Share on other sites
Samson 0 Posted January 22, 2008 Report Share Posted January 22, 2008 Hi c11rgd,The Crankshaft sits right at the bottom of the engine and the sensor is also right at the bottom of the engine.I had the EXACT same problem on my VR and the camshaft (different to the CRANKshaft) sensor is what was wrong with mine.The CAMshaft sensor sits on the right hand side of the head, right at the top of the engine, held in by one allen key bolt.You may have taken the coil pack off in order to take it out although some people manage without taking it off.The error message is definately reading CRANKSHAFT sensor, ive looked on ETKA but for the life of me can not find the crankshaft sensor listed or shown on diagrams, I will look when I have more time though. Link to post Share on other sites
Samson 0 Posted January 22, 2008 Report Share Posted January 22, 2008 by the way, you may need to clear any error codes just to give the ECU a clean bill of health otherwise it may still think the sensor is screwed. Link to post Share on other sites
adamsimmons 0 Posted January 22, 2008 Report Share Posted January 22, 2008 To make sure that the sensor has gone can you check the resistance across the sensor. The sensor should be white, and you need to measure across pin 1+2 and you should have a resistance between 480-1000 ohms with the plug disconnected, also check pins 1+3 and 2+3 there should be no continuity or open circuit between these pins. If any of these tests show any thing other than specified it will prove that the sensor is faulty. I hope this helps rectify your problem with your vr, I'm sure you will find it soon Link to post Share on other sites
adamsimmons 0 Posted January 22, 2008 Report Share Posted January 22, 2008 Also try checking these which can also affect starting of the engine when it's warm.Electrical connections - engine/batteryFuel pump non-return valveFuel pressure/delivery rate/fuel pressure regulatorFuses/fuel pump relay/engine control relay/fuel pumpCondition of fuel/fuel filterInjectorsIgnition systemAir filterAir intake system/vacuum system - leaksEvaporative emission (EVAP) canister purge valveMass air flow (MAF) sensorBarometric pressure (BARO) sensorEngine coolant temperature (ECT) sensorEngine management system - connections/wiringCrankshaft position (CKP) sensor/camshaft position (CMP) sensorEngine speed (RPM) sensorThrottle position (TP) sensorEngine compressionExhaust system/catalytic converterEngine control module Link to post Share on other sites
c11rgd 0 Posted January 22, 2008 Author Report Share Posted January 22, 2008 at this point the images i posted regarding the diagnosis originally were wiped clean. then when the car did cut out we checked it again and it was the CRANK sensor G28 only showing, as SAMSON mentioned i need the part number for this and not the one for the CAM. Link to post Share on other sites
VR6Pete 1,455 Posted January 22, 2008 Report Share Posted January 22, 2008 look on vagcat.com Link to post Share on other sites
c11rgd 0 Posted January 22, 2008 Author Report Share Posted January 22, 2008 SORTED FOR NOWPart no 021 906 433 C is the CRANKSHAFT POSITION SENSOR, ordered a new one its £75 ouch! Link to post Share on other sites
Samson 0 Posted January 23, 2008 Report Share Posted January 23, 2008 yeah they are much more expensive than the camshaft sensor but will be worth it if it sorts it. Link to post Share on other sites
c11rgd 0 Posted January 23, 2008 Author Report Share Posted January 23, 2008 seems to be ok for now. hasnt cut out yet, need to get a rear window regulator now. Link to post Share on other sites
swaper 0 Posted January 23, 2008 Report Share Posted January 23, 2008 I had the same problem last summer. After replacing many parts, i found out that the fuel pump was destroyed .... Check fuel pressure before ..... Link to post Share on other sites
biggee30 0 Posted February 4, 2008 Report Share Posted February 4, 2008 here are the diagnostic read outs. turns out it was the crankshaft position sensor. does anyone know where this is.c11rgdI am looking to get hooked up to my VR6 to fault diagnose.What code reader do you use and can you give any advice on cables/software for myselfcheers Link to post Share on other sites
c11rgd 0 Posted February 4, 2008 Author Report Share Posted February 4, 2008 not sure i think this one is called autodiagnose, a friend of mine is the specialist, there are a large variety ofmachines, even some from Snap on and Bosch any good trusted workshop should have this,For all this did sort out the Problem! the car needed a new CRANKSHAFT SENSOR< all sorted now! Link to post Share on other sites
kalv 0 Posted February 5, 2008 Report Share Posted February 5, 2008 Glad you got it sorted.. had same issue with mine.. How does the car feel? Mine seemed alot more sharper and responsive! Link to post Share on other sites
