HELP please im going to go mad
Right my car refused to start a while ago
done diognostics and it came up with
1-00513 Engine Speed Sensor - G28 - Idle RPM Too Low
00513 Engine Speed Sensor - G28 - Idle RPM Too High
00513 Engine Speed Sensor - G28 - Signal Malfunction
2-00668 Battery Power Voltage Supply (Terminal 30)
I know the engine speed sensor clears when the car is running so can ignore that
Is this defo the crank sensor cos 514 says crank position sensor where as 513 is engine speed sensor so are they both the same sensor or not??
I have tried a new crank shaft sensor to no avail
The low voltage is a presume cos my battery is half flat it cleared as i was jumping the car at the time of checking.
The car has no spark as far as i can tell so could it be the coilpack or something??
Right i have now replaced the cam and crank shaft sensors to no avail. Suspected the immobiliser but have been told it is not this as the car would start and then cut out.
What i have checked is
The fuel pump works
There are no fault codes
\I have 12v going to the coilpack when the ignitionis on
I have no spark
So it is eigther the coilpack or an ECU problem
Any other checks would be welcome??
