Right which bolts on subframe do I have to undo to lower it down to get ARB out......kinda guessing its 3 near ARB and one other big on e that you have to use a sucket on thro the wishbone.
Anyone confirm this as don't want to take out wrong ones. Oh and what size socket 3/4" went on ok but i'm thinking 18mm might be better but I only have 17 and 19mm sockets.
I really don't want to pay someone to do this as its quite easy to do by the looks of it.
Cheers
go for the front bolts first, take them all the way out, then thread then back in a few turns so they will support the subframe when you take the rear bolts out. Removal of the arb should be relatively easy, but take your time when putting the replacement in, especially if the arb bushes are new, I would expect you to swear a lot, there isnt much room, and the bush needs to be squashed a little when the clamp is in, so its a bit of a pain to do
