robvr6 0 Posted September 10, 2004 Report Share Posted September 10, 2004 just wondering if anybody has got a scan/link to a wiring diagram for stereo because the wiring in my new addition leaves a lot to be desired, and i've got a kenwood screaming to be fitted, also whats the best type of connectors to join the wires ? spade or them bullet things (free from work!)[ Edited ] Link to post Share on other sites
acf8181 0 Posted September 10, 2004 Report Share Posted September 10, 2004 ok, the original speaker wiring works like this...the fronts - one wire goes from h/unit to dash speaker, then another goes from the dash speaker down through the big plug into the door speaker.rear (3dr) - wire goes straight from h/unit to main speaker, then another wire comes from main speaker upto the tweeter. Link to post Share on other sites
robvr6 0 Posted September 11, 2004 Author Report Share Posted September 11, 2004 thanks,but ,was really needing colours for wires so i can rewire the thing, Link to post Share on other sites
acf8181 0 Posted September 11, 2004 Report Share Posted September 11, 2004 er, just check at the dash speaker...hopefully it'll say which is + and which is -, then compare it to where it meets the h/u Link to post Share on other sites
robvr6 0 Posted September 11, 2004 Author Report Share Posted September 11, 2004 d'oh ..... never thought o' that ! Link to post Share on other sites
madmonkee 0 Posted September 11, 2004 Report Share Posted September 11, 2004 just buy the adapter for the car, for the kenwood H/U Look on the adapter and it will obviousl Look at the adapter and you will figure out the wiring for the car, one block will have Constant live(normally RED) Then switching live(yellow) Negative(black) Amp remote(blue) Tel Mute(yellow and Black) Orange(another +) Then plug it into the loom of the car and note which is what. The other block will be all the speaker cables, easy really Link to post Share on other sites
robvr6 0 Posted September 12, 2004 Author Report Share Posted September 12, 2004 thats what i was wanting to do but someone has chopped the plug off leaving a mass of wire, Link to post Share on other sites
danb 0 Posted September 12, 2004 Report Share Posted September 12, 2004 If you go to halfords and buy the connector blocks for a mk3 golf ( £10 ish ) all the coloured wires on the connector blocks should match the ones on your car , just join the same coloured wires together , saves alot of time and head scratching . Link to post Share on other sites
robvr6 0 Posted September 12, 2004 Author Report Share Posted September 12, 2004 oh yes! hadn't thought of that, didn't realise they used the same coloured wires, i'll give it a try next time i'm near our local store, thanks Link to post Share on other sites
acf8181 0 Posted September 12, 2004 Report Share Posted September 12, 2004 you sure the halfords connectors use the same colour of wires? Link to post Share on other sites
robvr6 0 Posted September 12, 2004 Author Report Share Posted September 12, 2004 have just checked a halfords adapter for a ford, and the wiring is the same as the stereo,but doesn't really help that much because i don't know that the coluors match the vr.can't really see it being exactly the same..... Link to post Share on other sites
danb 0 Posted September 12, 2004 Report Share Posted September 12, 2004 Soz thought they were . If i get chance 2moz ill pull my stereo out and find out what wire does what as ive got a Kenwood in mine so they should be the same as yours ! Link to post Share on other sites
robvr6 0 Posted September 12, 2004 Author Report Share Posted September 12, 2004 cool, that would be a great help, Link to post Share on other sites
danb 0 Posted September 13, 2004 Report Share Posted September 13, 2004 Right ive checked for you , bare with me as someone at some point has cut the original plug off the loom and someone else has joined one back on again so ive had to trace the wire to the back of the dash . My advise is use a current tester aswell as the power leads are the same colour as a couple of the speaker lead kenwood loom = golf loomblack = brownyellow = red/whitered = brown/redorange/white = whitespeakersgreen = green/bluegreen/black = brown/redwhite = brown/whitewhite/black = red/whitegrey = brown/bluegrey/black = blackpurple = brown/blackpurple/black = red/green Link to post Share on other sites
robvr6 0 Posted September 13, 2004 Author Report Share Posted September 13, 2004 exellent, thankyou very much, i did manage to look inside the speaker grills today but there were 2 sets of wires to the rears,as expected, but strangely both sides were the same colour so will now have another look behind the h/u tomorrow and see what i can work out,and yes i have tester..thanks again for that Link to post Share on other sites
danb 0 Posted September 14, 2004 Report Share Posted September 14, 2004 You have two sets going to the rears because your tweeters in your back doors feed off the speaker . If you unplug one of the wires either the speaker will go off or the tweeter will . Link to post Share on other sites
acf8181 0 Posted September 14, 2004 Report Share Posted September 14, 2004 the wires form the the rear specker to the tweeter will be the same on both side...mine were. but the other wires going into the speaker should be different on each side. Link to post Share on other sites
robvr6 0 Posted September 14, 2004 Author Report Share Posted September 14, 2004 done it!!thanks to all who helped, only the rear drivers side speaker not working, will investigate tomorrow.. Link to post Share on other sites
danb 0 Posted September 15, 2004 Report Share Posted September 15, 2004 check the loom going into the door , unscrew it and check that non of the pins are bent and give em a squirt with wd40 Link to post Share on other sites
robvr6 0 Posted September 16, 2004 Author Report Share Posted September 16, 2004 right have done this,but still no worky, had the plug out what a sod of a job getting it back in ! and now the bloody window doesn't work, will have to have another look tomorrow and spray them with wd40,i presume this makes a better contact with the terminals ? Link to post Share on other sites
robvr6 0 Posted September 20, 2004 Author Report Share Posted September 20, 2004 been outside since 1 oclock, finally sorted e/window, was a dodgy wire that somebody has repaired and had come apart, also sorted the speaker, couldn't find a fault with the door so ran new speaker wires thro', all ok now thanks to all that helped Link to post Share on other sites
