Scotty 0 Posted September 11, 2004 Report Share Posted September 11, 2004 How much should I be looking to pay to get this done %-6 What Mileage Should This Be Done At /Still Learning This vr6 Caper [ Edited ] Link to post Share on other sites
andy 0 Posted September 11, 2004 Report Share Posted September 11, 2004 thread title changed so post now irrelevant[ Edited Sun Sep 12 2004, 08:03AM ] Link to post Share on other sites
VR6Steve 0 Posted September 11, 2004 Report Share Posted September 11, 2004 As a general guide, it seems most peoplr have it done around the 100k mark.Also its not so much a parts cost, but more labour as the gearbox needs to come out. Its also more down to the plastic chain guides wearing thin than the chains themselves needing replacement. However the chains do also stretch slightly too. Link to post Share on other sites
vdubgirl 3 Posted September 11, 2004 Report Share Posted September 11, 2004 Personally i'm not bothered about mine until they start to rattle my cars covered 111k and engine still sounds sweet as a nut :-) Seems alot of money to fork out for the tensioners to be changed when you dont necessarily need to have them done :-) Link to post Share on other sites
acf8181 0 Posted September 11, 2004 Report Share Posted September 11, 2004 the parts cost about £100 from GSF (they're genuine ones, but cost half the price of the same items from vw)labour would most likely be a good 4-6 hrs at least.its a bit of a game of russian roulette to wait till they rattle, its concievable that if the wrong tensioner or runner let go it would immediatly jump loads of teeth and trash the engine.however, from what i've been reading, later (obd2) cars are much less likely to have problems.i reckon on obd1 its a must...they always wear down the upper tensioner 'blade' runner. obd2's have a single row top chain, so it wears that item less. Link to post Share on other sites
madmonkee 0 Posted September 11, 2004 Report Share Posted September 11, 2004 so how would one know when it was time for a change?? Link to post Share on other sites
VR6Pete 1,455 Posted September 12, 2004 Report Share Posted September 12, 2004 you will get a rattle between 1,000 and 1,200 RPM normally, sounds abit like a sewing machine! Link to post Share on other sites
Glyn Mk3 0 Posted September 12, 2004 Report Share Posted September 12, 2004 If anyone wants to hear the six pot sewing machine let me know &| Link to post Share on other sites
acf8181 0 Posted September 12, 2004 Report Share Posted September 12, 2004 you will get a rattle between 1' date='000 and 1,200 RPM normally, sounds abit like a sewing machine![/quote']well, that actually means they should have been changed already. if its rattling, the chain could theoretically jump teeth any second.theres a sound clip of rattling chains on this page - http://forums.vwvortex.com/zerothread?id=1127339the best thing to do is to remove the coilpack, inlet, cam cover, tensioner bolt, and upper cover...then have a look at the condition of the runners that you can see (you won't be able to see the lower ones fully, but shine a torch down there. if the upper tensioners are still perfect then in all likelyhood the bottom ones are too. be prepared to see the top blade about to fall apart if you have an obd1 car on about 120k! lol Link to post Share on other sites
