Second hand supercharger
It is an a/c set up and comes with everything he had running on his OB1 engine. He says he put it straight on his standard engine with no re-map and it ran fine. I'm putting it on an OB2 engine and i'm not sure if I would need a re-map or larger injectors etc?
Sound to easy to me????????
Standard ZR2 is 6psi and you won't be able to just 'Bolt on and go'. £350-£400 Remap' date=' front engine mount and deffo exhaust is required and i'd also recommend an oil cooler.
Expect a realistic 250-260bhp without water injection.
I can get a chip from the guy for £150. Will I need this for the remap.
Thanks for the help.
wouldnt bother, better off with a custom map specific to your engine
If the guy ran it on a standard map his engine must be screwed now! I only kept the standard map for the run in period and didnt exceed 4000rpm until properly remapped
