VR6_Absy 0 Posted March 4, 2008 Report Share Posted March 4, 2008 Somehow my crankshaft pulley has worked its way loose and subsequently worn away the bore of the pulley, so i need a new one.Anybody fitted a lightened pulley ? Can anyone recommend a supplier ?CheersGary Link to post Share on other sites
dubdub 0 Posted March 4, 2008 Report Share Posted March 4, 2008 I assume these pulleys are secured vitha woodruff key as well (I could be wrong) If this is the case then it will need to be replaced as well. Also check slot for wear that may have been caused by chatter when pully loose. Lightweight pulleys should be your last consideration as they offer no improvement at all. IMO Link to post Share on other sites
VR6_Absy 0 Posted March 4, 2008 Author Report Share Posted March 4, 2008 yeah i need woodruff key as well Link to post Share on other sites
gav_113 0 Posted March 4, 2008 Report Share Posted March 4, 2008 i would check end of crank shaft as well!!slot may be fooked?? Link to post Share on other sites
6potmkII 0 Posted March 4, 2008 Report Share Posted March 4, 2008 i have a spare if you need one,,,, Link to post Share on other sites
VR6_Absy 0 Posted March 5, 2008 Author Report Share Posted March 5, 2008 pm sent Link to post Share on other sites
