brownbear 0 Posted March 5, 2008 Report Share Posted March 5, 2008 are there any advantages in a passat vr6 lump going in to a mk2 golf? as i have an opportunity to buy one (whole car)i think i heard something about the pedal box blah blah blah, cant remember. Link to post Share on other sites
VR6Pete 1,455 Posted March 7, 2008 Report Share Posted March 7, 2008 look at my project thread mate, ive just dont a mk2 VR6 build, listing all the parts I used to get it in a mk2 shell Ok... Here's a list of stuff I've put on the mk2 from the mk3, including other bits needed to complete my conversion.From the mk3:Petrol Tank (optional, just easier to replace it rather than messing about with fuel pumps, i'm lead to believe the 8v has a different pump than the 16v golf - not sure if anyone can confirm this?)Steering ColumnIgnition Barrel / key etc..Indicator StalksMk3 Steering WheelMk3 Gear Shift GatorMiltek Exhaust (with mk3 exhaust hangers chopped from my mk3)6 Branch ManifoldDe-cat pipeMk3 Brake Servomk3 samco's - 2 hoses not usedMk3 wide track - 5 stud wheel (will require new stretch bolts, front / rear)Mk3 PAS steering rackmk3 Eibach Front ARBMk3 Koni CoiloversMk3 Wheels (needs a slight bit of arch work, nothing a grinder cant sort on the front arches, I need 2 new ones anyway, so will be rolling them properly when I have it re-sprayed)Mk3 Brake SetupSubframe / Axle stretch boltsMk3 engine loom / fuseboxMk3 Floor MatsOther Parts:Corrado VR6 front cross-memberCorrado / Passat Peddle Box (for hydrolic clutch)Corrado VR6 twin fans + radiatorAuxiliary Belt - I've now ditched the Air Con compressorReplaced due to damage etc..Vibra Technics rear engine mountGear Box Case and mountNew ClutchNew HT LeadsTop / Bottom Samco Hoses for Corrado VR6 radiatorSump needed welding upexhaust heat wrapCant think of anything else at the moment, will add if I remember anything else Link to post Share on other sites
brownbear 0 Posted March 9, 2008 Author Report Share Posted March 9, 2008 i wanted to remain four stud buddy as ive got some awesome rims for it Link to post Share on other sites
vdubgirl 3 Posted March 9, 2008 Report Share Posted March 9, 2008 I've remained 4 stud on my Mk2VR6. You can use the Passat pedal box for the Hydralic Clutch conversion. But to do the Big brake conversion you will need either a Late Mk2 16v or older 4 stud passat for the hubs.For lots more info on Mk2 VR6's got to www.mk2vr6.com Good luck with the conversion Link to post Share on other sites
kilokilla 0 Posted April 16, 2008 Report Share Posted April 16, 2008 If you have bolt on calliper carriers on your mk2 you can get the early 280mm vr6callipers and carriers and use g60 280mm discs aswell mate . Link to post Share on other sites
