VR6osis 0 Posted April 2, 2008 Report Share Posted April 2, 2008 I have a VR6 Golf Auto, , Could anyone please advise on the cheapest and corret oil, as VW charges £60.00+ for 5.3 litres of ATF Detrox, I have seen much cheaper brands in motor accessorie shops, but their book only recommends the manual and not auto oil.Cheers (a) Link to post Share on other sites
bigjak 0 Posted April 3, 2008 Report Share Posted April 3, 2008 I have been trying to find the same info myself but all I can find is other people asking the same question (UK MK5 website) and the advice that I have found is get a specialist to do it as when you drain the oil and change the filter, some old oil might still be left but a specialist has the equipment to 'pump' the new oil in. I am going to call my local specialist and I will post the price they quote as a guide. Link to post Share on other sites
bigjak 0 Posted April 4, 2008 Report Share Posted April 4, 2008 Got Quote £160+VAT bit pricey...See Linkshttp://www.blauparts.com/vw/vw_fluid/vw_automatic_transmission_fluid.shtmlhttp://www.imperialoil.com/Canada-English/Files/Products_Lubes/IOCAENPVLESAtf_Dex_III_Mer.pdf Link to post Share on other sites
VR6osis 0 Posted April 8, 2008 Author Report Share Posted April 8, 2008 Thanks for your help bigjak with the links and info, I have spoken to vw dealer and they say it is possible for DIY oil changes on the auto gear box, when I have successfully changed the oil I will better equipped to give practical detailed advice, and will post it here soon.Cheers Link to post Share on other sites
vr6goose 0 Posted May 8, 2008 Report Share Posted May 8, 2008 if its the 01m auto box (fitted from 96 on apparently) theres lots of info on vwvortex I need to take a look @ mine as its bumping into gear irst thing in morning so deffo low on atf handy hows there is no dipstick lol Link to post Share on other sites
LSK_ZA_VR6 0 Posted May 8, 2008 Report Share Posted May 8, 2008 since iv'e been having hassles with my 5speed (09B type, fitted on V6 since 2001) box i spent some time with the local VW workshop Sup who knows a bit about the Sharan. The ATF recommendation is DEXRON III or equivalent as minimum spec. VW ATF surely is expensive ...apparently there is a red fluid (that's how i know ATF to look like) and then VW uses a yellow oil in some boxes - filled for life ?? (apparently the 09B uses the yellow fluid - mine was red :-o)the filter on the 09B type box can only be replaced by removing and splitting the box !!i have VW documentation on the process of checking for oil level and filling, etc. on the 09B type. please PM as it's PDF. or should i post? Link to post Share on other sites
