paulrom 1 Posted April 7, 2008 Report Share Posted April 7, 2008 like it says the fan on mine won't turn off have replaced the expansion bottle and the cap tonight as found it was lettig by as the cap was knackered is the box under the bottle related to the fan and am i right in saying that the brone plug on the front of the engine is for the fan switch ?????should i try replacing the fan switch 1st or look at the box under the expansion bottle ?????HOPING YOU GUYS CAN HELP REGARDS PAUL Link to post Share on other sites
thegoth 5 Posted April 8, 2008 Report Share Posted April 8, 2008 Your are right, the box under the expansion tank is the fan controller. The normal running fan control switch is in the radiator, just by the PAS bottle IIRC. The switch on the thermostat is for the after run cooling.Try disconnecting both, one at a time as it could be either. This will tell you if one is stuck closed. But if your expansion bottle has been dropping water all over the controller it might be at fault, or might just need drying out.In the meantime pop the fan fuse out to stop it. But remember to put it back before you go driving!TG Link to post Share on other sites
paulrom 1 Posted April 8, 2008 Author Report Share Posted April 8, 2008 thanx m8 the fan only runs with the ignition on so the fuse isn't a problem but it shouldn't be running all the time so i disconnecftedthe rad switch and it made no difference the fan was still running but if i disconnect the brown multi plug from the stat housing down by the fan on the engine the fan stops ??????? is it this stat that needs replacing or you still recon it's the control box have taken that off tonight and had a good look round can't see any water in it but heh who knows Link to post Share on other sites
jezmoz 0 Posted April 8, 2008 Report Share Posted April 8, 2008 sounds like the temp sensor ( brown multiplug) has had it mate try replacing that. Link to post Share on other sites
paulrom 1 Posted April 8, 2008 Author Report Share Posted April 8, 2008 the brown multi plug (temp sensor ) is that anything to do with the fan then ???? also where is the dash temp sensor as i'm not so sure that that is wrong as well as it never goes over the 1/2 way mark ever *-) *-) *-) Link to post Share on other sites
Bobtrude 0 Posted April 8, 2008 Report Share Posted April 8, 2008 The fan sensor is in the radiator on the left side. (looking from inside the car) It might be that. Do you have a bentley manual, they show how to check the sensors often with a voltmeter. Link to post Share on other sites
Phat VR6 3 Posted April 8, 2008 Report Share Posted April 8, 2008 If it stops when you disconect the brown plug it seems to indicate that your problem... And half way on your temp gauge is perfix Link to post Share on other sites
paulrom 1 Posted April 9, 2008 Author Report Share Posted April 9, 2008 all sorted got home tonight and shot down to vw dealership and got me a new thermostat (brown plug ) and fitted it all mendedthe brown plugged stat is for the 3 stage fan selection hese if it's knackered it just sends the message run at full bore LOLice is in as welll sounds awsome so all in all a good night :-p :-p :-p thnx guys for the help Link to post Share on other sites
jezmoz 0 Posted April 11, 2008 Report Share Posted April 11, 2008 nice one Link to post Share on other sites
