MOT Problems with my VR S/C.....Need some help if possible. !!!!!
HI,
Just had my VR with Z Engineering MOT'ed and it's failed.....
It's failed on Lower arms and brake pipes which is not that bad but it's also failed on emissions as the Cat has been removed. !!!!!!
They also noticed the ABS light does not work. I've just checked it and found out that the bulb has been cut as the light is on constantly !!!!!!!!!!!!!
Does anyone that a spare Cat for a P reg VR ??? who's near Licester that i could buy or borrow to get mine through the MOT. ???
Thanks,
Mark
If they tested it for emissions as a VR6 then you could argue that they shouldnt have done as VW never made a supercharged VR6 engine so technically it should be tested as and 'unspecified' engine, which I here is an option when setting up
If they tested it as 'unspecified engine' the emissions test is alot more leaneant and would more than likely sail through, even without the cat
Im sure if im wrong someone will say so, but im positive Ive seen this loop hole somewhere since the New Year
