lewvr6 0 Posted April 20, 2008 Report Share Posted April 20, 2008 Snce getting my lastest VR a 96 obd2,ive been donig various maintence bits on it,yesterday got round to cleaning the throttle body.All went fine and looks spotless now,Before starting the car after refitting throttle i had disconnected the batt and 'reset' the throtte alignment (as per the hall sender cleaning guide on here). Started the car and revs went up to 2k then dropped to 1500 where it stays now when cold.Idle eventually settles down to normal when warm but does take a while to settle back down when driving-e,.g if stopping at a junction-will stick at 1500 then slowly drop to normal.Making it difficult to drive now as the revs 'stick' when changing gear and only drop if you hold clutch in for a couple of seconds?Checked all the usual-no vacuum leaks,all pipes and hoses ok,throttle cable is adjusted fine.Any help much appreciated Link to post Share on other sites
gkjnr 0 Posted April 20, 2008 Report Share Posted April 20, 2008 it will sort itself out after driving for a while i,m led to believe mate Link to post Share on other sites
lewvr6 0 Posted April 20, 2008 Author Report Share Posted April 20, 2008 Thats what i thought from reading various threads on here,but have been out few times and it still hasnt improved!Will have to see if it improves over the week.Any other suggestions? Link to post Share on other sites
Devildub_06 0 Posted April 21, 2008 Report Share Posted April 21, 2008 Did you clean the throttle body in situ or remove completely, maybe that you sent some gunk down the tube for the idle bypass, in which case give that some love too. Link to post Share on other sites
Advr6 0 Posted February 12, 2009 Report Share Posted February 12, 2009 I had the same problem wiv mine a bit of driving should sort it right out Link to post Share on other sites
