hopefulVR6owner 0 Posted April 22, 2008 Report Share Posted April 22, 2008 my water pump has gone but i am able to do the job as i have the facilities, just wondered if there was anything else that is worth doing as i am in that area of the engine other than the belt? Link to post Share on other sites
SankysVR6 1 Posted April 23, 2008 Report Share Posted April 23, 2008 Theirs not really anything else around that area that's worth changing, apart from the coolant which is obvious. You could replace your engine mounts if your feeling flush, as you will be loosening them anyway. Link to post Share on other sites
petervr6 0 Posted April 23, 2008 Report Share Posted April 23, 2008 i would change the belt that drive`s the pump while your taking it off and check the tensioner bearing and maybe grease it.. Link to post Share on other sites
hopefulVR6owner 0 Posted April 28, 2008 Author Report Share Posted April 28, 2008 done it last friday replaced pump, drive belt and got 5ltrs of g12 for £70 all in! found it easy to do and probably the easiest cooling system i have ever had to bleed! done the whole lot in just shy of an hour. Link to post Share on other sites
