j933 vrd 0 Posted April 27, 2008 Report Share Posted April 27, 2008 i dont normally give it any untill its warm. but a few times recently. when i put my foot down, when the oil temp is 50 ish it seem to pull a lot harder and faster then when its up to about 80 ish? why would that be? thanks Link to post Share on other sites
xyber 1 Posted April 27, 2008 Report Share Posted April 27, 2008 Have you got an induction kit? If its sucking in warm air that heated by the engine it would feel abit slower Link to post Share on other sites
Eat this 2 Posted April 27, 2008 Report Share Posted April 27, 2008 it shouldnt pull alot harder unless youv got an underlying issue mate Link to post Share on other sites
j933 vrd 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 pipercross cone filter. i was thinking maybee a sensor of some sort? Link to post Share on other sites
j933 vrd 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 been on 2 diagnostic machines, and none of them would read it??? Link to post Share on other sites
Lizard Racing 0 Posted April 27, 2008 Report Share Posted April 27, 2008 The bores are either very worn or the coolant temp sensor is faulty. Link to post Share on other sites
Lizard Racing 0 Posted April 27, 2008 Report Share Posted April 27, 2008 Ignore that, Ive just re-read your post and im talking utter bolx Link to post Share on other sites
Bobtrude 0 Posted April 27, 2008 Report Share Posted April 27, 2008 Get a heat shield. . . . . .. Neuspeed.com or many other. I have the same problem and gonna try to fix it with a shiel, but i have turbo so the IC piping will have to be rerouted first. Link to post Share on other sites
xyber 1 Posted April 27, 2008 Report Share Posted April 27, 2008 something like a BMC CDA or PiperX Viper would be good as it isolates the cold air going to the inlet and the ram effect is noticable when you boot itand a low temp stat is worth doing Link to post Share on other sites
j933 vrd 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 HAD A VIPER ON, WASNT KEEN ON IT. TAKES AWAY THE VR NOISE. NOBODY THINKS A SENSOR??? ANYONE LOCAL WITH VAGCOM? Link to post Share on other sites
vw_golf_vr6 0 Posted April 27, 2008 Report Share Posted April 27, 2008 i agree about heatsheild for the filter or mod a stock airbox so the cone filter fits in, can cut top of airbox off as well Link to post Share on other sites
Phat VR6 3 Posted April 27, 2008 Report Share Posted April 27, 2008 Looks like somones got a headlight missing to aid cold air feed lol. I always thougth heat soak happend more in traffic and on hot days.. So it could be pointing towards a sensor. If you got a laptop then ebay vag.com its only cheep Link to post Share on other sites
j933 vrd 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 did have when i had viper on... got fk angels now. my mate has just told me he got vagcom. will have to get it on n c what happens Link to post Share on other sites
jaysVR6 2 Posted April 27, 2008 Report Share Posted April 27, 2008 The car is pulling timing and fuel at that temperature as it's still on choke. Combined with cold air it will feel more pokey.Thing is, carry on driving it like that from cold and you'll kill it, plain and simple. Link to post Share on other sites
j933 vrd 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 just the odd time i have had my foot down i have noticed it. what your sayin is i need more fuel??? Link to post Share on other sites
jaysVR6 2 Posted April 27, 2008 Report Share Posted April 27, 2008 Nope mate, the car is running perfectly normal. Link to post Share on other sites
vr6newcomer 1 Posted April 27, 2008 Report Share Posted April 27, 2008 when you say "had to put my foot down" what sort of rpm's & speed are you talking about? Link to post Share on other sites
Bobtrude 0 Posted April 27, 2008 Report Share Posted April 27, 2008 Dont answer that;). I feel it in my car aswell, and i dont need high rpms, just 2000 to 3200 rpm with full throttle. Link to post Share on other sites
j933 vrd 0 Posted April 28, 2008 Author Report Share Posted April 28, 2008 sounds the same as bobtrude`s. why have you any ideas??? Link to post Share on other sites
Bobtrude 0 Posted April 28, 2008 Report Share Posted April 28, 2008 Its just heatsoke mate. It gets better when u dont have to stand still and dont get any cooling air. And you should bypass your inteke manifold water lines so you dont heat it up even more. . . . . And get a big ass hoodscoop and a fan like this http://www.astroshow.com/Alaska07/348BigSnowBlower.jpgThen youre good to go. Link to post Share on other sites
xyber 1 Posted April 28, 2008 Report Share Posted April 28, 2008 give the new oil, low temp stat and new coolant a go, you will be surprised, just the fresh oil will knock the temps down a few deg i found Link to post Share on other sites
j933 vrd 0 Posted April 28, 2008 Author Report Share Posted April 28, 2008 i have bypassed the throttle body water hoses, if theyre the same thing?? that heatcoop wouldnt suit my car i dont think...lol might go back to a sealed induction kit then. thanks matey Link to post Share on other sites
j933 vrd 0 Posted April 28, 2008 Author Report Share Posted April 28, 2008 the car overall doesnt run hot. rarely gets half way up temp guage, where as my mates sits at half? doing oil this week anyway so we`ll c. cheers guys. Link to post Share on other sites
Bobtrude 0 Posted April 28, 2008 Report Share Posted April 28, 2008 give the new oil' date=' low temp stat and new coolant a go, you will be surprised, just the fresh oil will knock the temps down a few deg i found[/quote']where does the low temp stat sensor sit? Yes was the manifold coolant lines i meant. Link to post Share on other sites
j933 vrd 0 Posted April 28, 2008 Author Report Share Posted April 28, 2008 it replaces your old stat. Link to post Share on other sites
