gypowagen 0 Posted April 27, 2008 Report Share Posted April 27, 2008 I am hoping to receive my carbonio cold air induction kit in the post tomorrow, and in preperation for this i decided to remove the air box and clean the chassis leg underneath etc, but from what i can make out from where the filter sits there is a canister under the air box with two pipes going to it which looks to me like some sort of filter, firstly does this have to be replaced at any time, and secondly does it have to be moved to allow the carbonio filter to be fitted or does the filter fit above or below it??? any help on this would be great, cheers Link to post Share on other sites
xyber 1 Posted April 27, 2008 Report Share Posted April 27, 2008 Yep thats the charcoal canister, just take it off and plug the black hose and leave the other hanging down inside the wing Link to post Share on other sites
gypowagen 0 Posted April 27, 2008 Author Report Share Posted April 27, 2008 ok so what does it do? and where do the hoses go? can you be more precise? i'm a bit thick, cheers Link to post Share on other sites
xyber 1 Posted April 27, 2008 Report Share Posted April 27, 2008 It basically recycles fuel tank vapour back into the inlet manifold and is controlled by vacuum, thats why the black hose needs pluggong else you would have running problemsThe clear pipe which you hang inside the wing will then just sit there and allow the fuel tank to vent vapour safelyclear hose runs back to the tank, black one runs to a small valve, then up to the left hand side of the inlet manifold and hooks up to the crankcase breather, which then goes to the inlet pipe just before the throttle body, from what I rememberIf you give the canister itself a firm wack with your hand from underneath it should just pop of the clips its mounted to Link to post Share on other sites
