jec 0 Posted May 1, 2008 Report Share Posted May 1, 2008 K reg mk3 Golf VR. I need to change the fuel pump. I've heard this isn't an easy job as the pump pushes into the tank and is pretty fiddly, does this sound about right? Has anyone got any tips for making the process go any easier?thanks in advance!jc Link to post Share on other sites
Phat VR6 3 Posted May 1, 2008 Report Share Posted May 1, 2008 I found it very fiddly and asked the same qweston but didn't get an anser. Just don't get pissed off with it and take your time and it will come outWhat i did was remove the little rubber mounting blocks one at a time, 3 in total and it will come out alot easyer than leaving them inHope this helps Link to post Share on other sites
jec 0 Posted May 1, 2008 Author Report Share Posted May 1, 2008 thanks for that! I saw your post and that it had no replies... Can you remember how long it took?thanks, jc Link to post Share on other sites
Phat VR6 3 Posted May 1, 2008 Report Share Posted May 1, 2008 about ah hour tops to work out whats going on and to get it out. I thougth it might have been twist fit or some little clips i couldnt find but it isn't Link to post Share on other sites
