xyber 1 Posted May 1, 2008 Report Share Posted May 1, 2008 If the GB on schricks goes ahead im gonna have one so whilst ive got that area in bits in gonna clean the MAF and hall sensor and put on some monster leads and new plugsJust wondering what the benifit is of using different plugs? as I understand the cooler plugs from a 1.8t or S2 are favoured but what the advantage of using them?cheers Link to post Share on other sites
Eat this 2 Posted May 2, 2008 Report Share Posted May 2, 2008 mines got s2 plugs init no problems Link to post Share on other sites
Devildub_06 0 Posted May 2, 2008 Report Share Posted May 2, 2008 The "cooler" plugs transfer heat away from the firing tip faster preventing overheating (as you well know this causes the plug to break down and cause misfire). The same can be said in vice versa about "hotter" plugs which transfer heat away from the firing tip more slowly (these are used on cooler running engines where extra heat is needed in the plug to prevent coking up). Link to post Share on other sites
xyber 1 Posted May 4, 2008 Author Report Share Posted May 4, 2008 mines got s2 plugs init no problemswhat gap did you use? or just as they come? Link to post Share on other sites
Eat this 2 Posted May 4, 2008 Report Share Posted May 4, 2008 just as they come Link to post Share on other sites
mike 6 Posted May 4, 2008 Report Share Posted May 4, 2008 is tthere any point in gettin diff plugs on a n/a vr? like mine with just an exhuast/air filter?guessin id need upgraded cams etc to notice any difference? Link to post Share on other sites
