got some goodies fitted yesterday
kw v3 suspension
nuespeed arbs 25 mm front 22 mm rear
full set of polybushes
75% short shifter
1 deg neg camber on the front
omg its a beasty now 1st impressions of the suspension are its the mutts nuts the front feels a bit lower and is deffo softer than the rear (great drag setup) im gonna stiffen the buond and especially the rebound and probably raise it a touch
its alot more tail happy now
the front ends got a hell of alot more grip
it turns in quicker
its far more adjustable on the throttle (the throttles horrible so its actually a pain atm)
the bushes make it fell tight as fook
it carries far more speed through corners
basically its awesome if youv got the cash go for it it really transforms the car
how much was it then as ive heard using the r32 or even tt suspension is a gd alternitave
i was usin the r32 suspension and arbs (now sat in garege if you want it) its alot better than 4 mo stuff but this is a different planet its fantastic
ps yeh id put some camber on the mk3 got nowt to lose and you could always put it back i even thought about a littole toe out at the front but it doesnt seem to need any lol
